Ansys Learning Forum Forums Discuss Simulation Electronics Plot Antenna Power vs Distance Reply To: Plot Antenna Power vs Distance
AncS
Hello Mitchell,
You can follow these steps to plot mag vs distance:
  1. Draw a non-model line of the desired length pointing away from the dipole antenna outside the simulation box.
  2. Add a near field line setup using this line.
  3. Create the near field report using the rectangular plot. In the report dialog window, under Category, choose the desired option (near E or Near Poynting) and click New Report.
  4. You will get the desired quantity vs normalized distance plot.
Hope this will help you.
Regards
Anchal
