Ansys Learning Forum Forums Discuss Simulation Fluids Magnified icons in CFDPost Reply To: Magnified icons in CFDPost
V.P
Solution:
Try adjusting the DPI settings specifically for CFD-Post:
Right-click on the CFD-Post application or its shortcut.
Go to Properties → Compatibility tab. In the settings section, you will find 'Change high DPI settings'.
Check the option 'Override high DPI scaling behavior' and set it to 'Application'.
Apply the changes and restart the application.
