Ansys Learning Forum Forums Discuss Simulation Fluids Drone zero lift help Reply To: Drone zero lift help
Click "per zone" on the report panel as the drone body won't help the sums. With mrf can you run steady? You've done about 10 time steps to get to 0.1s so I'm a little concerned that it's a settled result. You also have a spinning blade that's not just generating force in the y-axis.
