Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS-PrePost: Flow through 3D Rectangle Channel including Flap. › Reply To: LS-PrePost: Flow through 3D Rectangle Channel including Flap.
Hi Alex,
Thank you for your reply.
I went through that tutorial and reviewed the k files.
However, my case is different, The rectangle centered within the main fluid domain is a surface (no physical volume) floating slightly off the ground, where as the intermediate_fsi_flap case the thickness of the flap is fixed, I believe.Â
I tried running a case where the rectangle plane was connect to the floor and meshed them together however I still got the same error.Â
Also, the version I am using is LS-PREPOST V4.10.3, see image below.Â
Thank you for your assistance.Â
