Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Injection setup › Reply To: Injection setup
September 24, 2024 at 4:24 pm
On the particle tracks there's a time value to report.
The two models are slightly different in the near wall region, given the flow field that may extend into the bulk of the throat. At the speed you're seeing small changes may be sufficient to cause a larger change in the trajectories.
