Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Line Body/Beams Lose Vertices on Transferring Solution Data › Reply To: Line Body/Beams Lose Vertices on Transferring Solution Data
September 20, 2024 at 3:30 pm
Deepak,
In analysis A-B im performing a linear buckling analysis.Â
I export the deformed body based on the mode shape from analysis B for nonlinear buckling with deformations into Analysis C. The bolts modelled as beams cannot be selected for bolt pretension. Is there a workaround?
Thank you! Â
