Ansys Learning Forum Forums Discuss Simulation General Mechanical Line Body/Beams Lose Vertices on Transferring Solution Data Reply To: Line Body/Beams Lose Vertices on Transferring Solution Data
drdmsthesis
Thanks Deepak,
The “create geometry” boxes were unticked in my case. The fix worked.
Also, how can beam elements remain “rigid” after transferring solution data so I can apply bolt pretension to a straight line/edge?
