Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Pin connection (hinge) between solid element › Reply To: Pin connection (hinge) between solid element
Ram Gopisetti
Hi
When you say hinge, you have two methods,
CNRB approach: create a CNRB ( constrained nodal rigid bodies) connection between two solid parts and then resolve the components via (Boundary_ prescribe _ motion_rigid infer the PID of this CNRB )such that rotation is free and the rest of the components are 0
Joint approach: you can model the revolute joint as given in the link
Also, on a simple approach, you can use the SPC with a Rotational component to 0
Happy Simulation,
Ram.
