Ansys Learning Forum Forums Discuss Simulation Electronics two motion set up for one model Reply To: two motion set up for one model
ctunceroglu
Because I need to create a second band inside the barrel to see how much it rises, but in that case, the bands will intersect. If I create two half-cylinder bands inside the barrel, I’m not sure if I can perform both the rise and forward movement analysis for a single object.
