Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Reinf265 as steel wire reinfocements for spiral arrangements APDL › Reply To: Reinf265 as steel wire reinfocements for spiral arrangements APDL
muhammadaziz.sarwar
Yes. Thanks for your response .Yes the properties you mentioned describe the defination and properties .In my approach all fibres have same steel properties with same angle of helix and same distance between each fibre ,But I had another question and that was mentioned in the above query as well.Is smeared approach using the average approach for calculating material properties means they are averaging  the base property and reinforcing property of material,if base material property is considered.Please reply.
