George Karnos
Hello Hani,
From a dos command prompt, try to ping the license server from the AWS machine.
It may be a DNS Issue.
Can you ping the hostname that is in the license file: cue-lic-vm-01
Also, the vendor port should not be set to use 2325. That willl interfere with the Interconnect with older versions, which uses 2325.
Set the vendor port to 1056, if open:
SERVER cue-lic-vm-01 DISK_SERIAL_NUM=f852cb72 1055
VENDOR ansyslmd port=1056
USE_SERVER
