Ansys Learning Forum › Forums › Discuss Simulation › Photonics › EME Mode Sweep Not Converging › Reply To: EME Mode Sweep Not Converging
Sept
Hi Amrita,
thank you for the fast reply. As of now I am simulating the same number of modes in the straight waveguide sections as I am in the taper region. I have also noticed that for this geometry in theory the longer the taper length should be the closer it should get to converging S21 and S12 equaling to 1. According to my results after a certain length my S parameters max out at about .94 and then start dropping in value the longer it is.
Sincerely,
-Lucio
