Ansys Learning Forum Forums Discuss Simulation LS Dyna Units System in LS Dyna Reply To: Units System in LS Dyna
p20230481
Thank you.
Could you please suggest me which model I could use to introduce shock wave inside shock tube? Task of this shock wave will be to do forming of sheet metal inside shock tube.
Remember that this shock wave is not produced by a blast, rather inside a shock tube due to high pressure diffrence between the two chambers of the shock tube.
