Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Failed Parallel Simulation using MotorCAD Blackbox License with OptiSLang › Reply To: Failed Parallel Simulation using MotorCAD Blackbox License with OptiSLang
abhijith.udayan
Hi Mingzhe,
From the screenshot you provided, it appears that all the steps you followed are correct. However, the error in the export file suggests that the issue might not be with the black box. You might want to check the Ansys License Manager as well. I recommend trying an already solved tutorial example to see if the issue persists.
