Ansys Learning Forum Forums Discuss Simulation General Mechanical Stress too high in transient simulation. Reply To: Stress too high in transient simulation.
danielshaw
If you are sure that the alternating stress is below the endurance limit, you can assume infinite life. Based on the S-N curve that you showed, this material appears to have a well-defined endurance limit at about 450 MPa, but in general
  1. Not all materials have a well-defined endurance limit.  So, if the part experiences very high cycle fatigue, you may not be able to assume infinite life,
  2. 450 MPa seems like a relatively high endurance limit.
