Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Drop Test › Reply To: Drop Test
peteroznewman
Calculate the impact velocity from the drop height using the equation or an online calculator https://calculator.academy/impact-velocity-calculator/ using the units in your model.
In CAD, move the sphere so it is tangent to the panel.
In Mechanical, insert an Initial Velocity under the Initial Conditions folder and assign the impact velocity to the sphere body.
Under Analysis Settings, Output Controls, increase the number of output frames from the default of 20 to 200 so you can see the details of the sphere flexing the panel.
