Ansys Learning Forum Forums Discuss Simulation Preprocessing ICEM-Fluent Integration Problems in Workbench Reply To: ICEM-Fluent Integration Problems in Workbench
zain.qazi
Which cell should I refresh? The project I dont want to refresh because that will update or refresh everything, don't need to risk that.
So for example I want to duplicate these three selected items with their connections. And then I want to refine the fluid mesh and the solid mesh before opening Fluent from the Solution tab. How would I do that? Currently if I try to open fluent after duplicating without changing the mesh, it gives prompts for non existing surfaces and misreads the interfaces
