Ansys Learning Forum Forums Discuss Simulation General Mechanical Is there a way to input residual stress data derived from other software Reply To: Is there a way to input residual stress data derived from other software
Nanda
Hello Kang,
Yes, it is possible to bulk data file(*.bdf) into Ansys for your fatigue analysis. Please refer to the below steps:
  • In the BDF (Bulk Data File) format you mentioned, please ensure the data includes each node’s stress tensor components (Sxx, Syy, Szz, Sxy, Sxz, Syz) before you export it.
  • In ANSYS Workbench, create a new Static Structural analysis system.
  • Import the geometry of your welded part into the Static Structural system.
  • Right-click on the Geometry cell and select “Import Geometry”. Browse to the BDF file exported from Simufact and import it.
  • ANSYS will read the residual stress data from the BDF file and map it onto the imported geometry. The stress tensor components will be available as solution data.
  • This solution data can be mapped to your fatigue analysis module
For more details, please refer to these links:
Importing Files (ansys.com)
WB import entire Nastran model .bdf (ansys.com)
Nanda.
If you are not able to open Ansys help links, refer to this forum discussion: How to access the ANSYS Online Help
Also, we launched a public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
