Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Injection setup › Reply To: Injection setup
September 1, 2024 at 5:07 am
I tried what you said, and i tried different things but happens the same.Â
I am working the flow with SST k-omega, but i tried standard k-epsilon and this changed, and i got what i needed.
this is what happens with k-omega,
But, even I have the same results for both for the flow, this changed with the particles, do you have if this is really something that can happen or should i consider something else if i am using sst k-omega for the particles?Â
Thanks in advance
