Ansys Learning Forum Forums Discuss Simulation Electronics an unknown error occured during solution Reply To: an unknown error occured during solution
George Karnos
Under %TEMP%\.ansys directory, you should see .out files
check those files for license information. Are there errors listed?
Also. if you lower the max core count in the Solve process to 2, does it run?
