Ansys Learning Forum Forums Discuss Simulation Photonics Using layer builder to add sidewall angle to a polygon Reply To: Using layer builder to add sidewall angle to a polygon
Guilin Sun
For imported structures, right now it is only from the laye rbuilder. What you might try is: import the structure layer by layer, with a little shrinked size (scale) to mimic the side wall angle.
