Ansys Learning Forum Forums Discuss Simulation General Mechanical Weird Strain Result Reply To: Weird Strain Result
SaiD
Hi, the deformation plot that you have shared here is unconverged (meaning that the results here don't represent the actual physical deformation). To figure out why the solution is not converging, you could look at Solution > Solution Information> Solution Output:Solver Output. You may find some error or warning messages there that might provide a clue.
If not, please share additional details about your simulation so that other forum users can help out: the objective of the simulation, geometry and material details, loads and boundary conditions applied, the analysis settings for all the 5 load steps etc. etc.
