Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Using layer builder to add sidewall angle to a polygon › Reply To: Using layer builder to add sidewall angle to a polygon
Guilin Sun
Planar Solid is composed of planar sufraces. For the topological design results, the sides might be too rough which will need too many planar surfaces. You may need to increase the min size from the first optimization result and see the resuling structure is improved.
