Ansys Learning Forum › Forums › Discuss Simulation › Fluids › PyFluent Watertight Meshing workflow › Reply To: PyFluent Watertight Meshing workflow
August 20, 2024 at 2:46 pm
Have you looked in the Ahmed body example? You may not find the exact command in one example and may need to pull information from different sources. There should be additional information in the PyFluent course on Learning.Â
