Ansys Learning Forum Forums Discuss Simulation 3D Design High temperature in the CFD results Reply To: High temperature in the CFD results
With a rotation speed of 6500 rpm what sort of tip velocity are you getting? Have you then resolved the flow in those regions: Nick's comment re the effected areas is also something to check. A monitor and warning isn't overly useful when diagnosing solution issues.
