Ansys Learning Forum Forums Discuss Simulation General Mechanical Preload between two parts Reply To: Preload between two parts
Giorgos Papa
Yes, it is possible to simulate preload between two solid parts that are screwed together.
One way is to use the Bolt pretension object. More information related to that can be found in Ansys Help documentation at the following link:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v242/en/wb_sim/ds_Pretension.html?q=bolt%20pretension
On AIC, we have a learning track on Pre-loaded Bolted Connections which could be useful to you.
You can access it by following the link below:
 https://innovationspace.ansys.com/courses/learning-track/pre-loaded-bolted-connections/
Kind Regards,
Giorgos
