Ansys Learning Forum Forums Discuss Simulation 3D Design In Discovery, How to extract a surface from a body consisting of closed surfaces Reply To: In Discovery, How to extract a surface from a body consisting of closed surfaces
Bob
Atharv, thank you for your answer.
I want to perform analysis by giving thin thickness through surface model. So I need surface model. Is there no other way?
Or is it not possible to disable the option that closed surfaces automatically convert solid to solid?
