Ansys Learning Forum Forums Discuss Simulation Electronics SIwave resonant modes result export Reply To: SIwave resonant modes result export
david.ferencz
Hi Rong,
Thank you for the quick answer!
If you are going to improve this functionality, could you please add the export option to the panel of numeric result of the solver as well?
The other issue I encountered is the quality of the manually exported plots/animations. According to my knowledge, I can only use the "Copy to clipboard" function to export plots of the current desktop view or the "Export" button for the "Phase animations". As I observed, the quality/resolution highly depends on the used display. With lower resolution displays (e.g. laptop), some details (e.g.component labels) cannot be seen well. In HFSS, there is an option to set the resolution of the exported image, so I think it could be implemented in SIwave, too.
My next question is also related to the resonant mode solver. If I like to perform a broadband analysis, I need to specify the number of modes for the solver. But, if I enter a number bigger than 30, I get this message:
Why is it limited? Is there any specific reason? I had to perform 10 different runs for my last analysis (up to 3 GHz) and this also makes harder the process of analysis.
Can I do some workaround (settings, change some variable, etc.) to resolve this problem?
Sorry for the long wish list :)
Best regards,
David
