Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › High temperature in the CFD results › Reply To: High temperature in the CFD results
August 16, 2024 at 9:13 am
It is shown in the final results. I have carefully checked the BCs. I havent faced this issue in persious versions and these issue appeared at different simulations with different CFD domains. As you see below, the max. temperate should be not exceed a 61C because we dont have a heat source in the system.
