Ansys Learning Forum Forums Discuss Simulation 3D Design High temperature in the CFD results Reply To: High temperature in the CFD results
NickFL
- Is it just for a couple of iterations and it goes away? Or does it persist throughout the solution?
- If you have an old saved solution, and using that for an initial condition, continue to solve and see if you get the message.
- Double and triple check all your boundary conditions. Are all the surfaces assigned the correct conditions?
