Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Normalizing intensity in extracted intensity plots › Reply To: Normalizing intensity in extracted intensity plots
Amrita Pati
Hi Ajay,
That is correct, the FDTD is a time domain algorithm, but at the end of the simulation, the DFT monitors convert the time domain results into frequency domain results using Fourier transform, so you see the electric/magnetic field results for different wavelengths/frequencies. If you would like to see the evolution of electric field over time using a time domain monitor. Could you explain a little bit more what exactly is the metric you are looking for? You may also share a reference plot/article. Thank you!
Amrita
