Ansys Learning Forum Forums Discuss Simulation General Mechanical Workbench Mesh Offset Related Question Reply To: Workbench Mesh Offset Related Question
mjmiddle
OK, I see you have bottom independent band turned on and the deepest blue contour color changed to white. And you have "Result > Edges > No wireframe." I can duplicate your offset display with or without thick shells and beams. It does not occur with top or bottom offset, only with user defined. However, I fail to see the problem. That is the point of the user defined offset.
