Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to modify in Design modeler after solution › Reply To: How to modify in Design modeler after solution
August 14, 2024 at 3:26 pm
Hello Gray,
I appreciated your response.
The model shown here is carried out as a surface body (not extruded). Hence, I cannot extrude the drawn square (sketch) because it cannot be extruded (the sliding menu cannot utilize extrude order – as shown in the picture).
It seems that the design modeler is locked after the solution is obtained
Regards
