Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › material with different modulus in tension and compression › Reply To: material with different modulus in tension and compression
Alex Rycman
Could you please look at the *MAT_SIMPLIFIED_RUBBER/FOAM. This material model provides a rubber and foam model specified with a single uniaxial load curve.
Thank you,
Alex
