Ansys Learning Forum Forums Discuss Simulation General Mechanical The number of nodes in the mesh details is not the same as the solution output Reply To: The number of nodes in the mesh details is not the same as the solution output
Kaushal Vadnere
Yes, you can use moment reaction object and scope it to remote displacement to get the moment required to turn the screw. Also, Is that the only warning or error messages are you getting? As you mentioned your solution is getting failed, it would be also necessary to debug the divergence.
