Ansys Learning Forum Forums Discuss Simulation Photonics Ring Resonator mode source issue Reply To: Ring Resonator mode source issue
Amrita Pati
Hi Fakhriyya,
When you select the first mode from the eigenmode solver, you have to make sure that in the "Effective Index" tab of the varFDTD simulation object:
Can you run the simulation after setting this and let me know if you see reasonable results?
Amrita
