Ansys Learning Forum Forums Discuss Simulation General Mechanical An error occurred inside the SOLVER module: Enclosure type Reply To: An error occurred inside the SOLVER module: Enclosure type
Rishi Yadav
I am getting an error with body split (image attached), and when I tried the face split, the face splitted into 4 parts. There is no body outside the enclosure. There is a build tray, on which a plate is placed on and on that plate there is a layer, which is getting heated. The process is in the vaccum. The heat shield is there (top structure) to prevent the heat loss. Radiation from heat shield is also playing a role in heating the layer. Can we connect over zoom?Â
