Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › The number of nodes in the mesh details is not the same as the solution output › Reply To: The number of nodes in the mesh details is not the same as the solution output
1617836513
Unfortunately there is no solution for now. I don't seem to have permission to view the article you posted. Like the picture I posted, slice the driver in two and set the remote point on the top section while the bottom section establishes contact with the screw. That would be a good way to try it I think? If this works, can the counter moment of the remote point of the count output be used as the maximum screw-in moment of the screw? Thank you sir.
