Ansys Learning Forum Forums Discuss Simulation General Mechanical The number of nodes in the mesh details is not the same as the solution output Reply To: The number of nodes in the mesh details is not the same as the solution output
1617836513
Yes, I set up a remote point. Do you mean the remote point is node 125915? I don't see node 125915 in the geometry using the node name search, what should I do to get rid of that warning to improve the calculation accuracy? Thank you!
