Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Cortex startup failure error issue: two-way fluid-structure coupling simulation › Reply To: Cortex startup failure error issue: two-way fluid-structure coupling simulation
August 8, 2024 at 1:41 am
Hello Federico !
 My fluid-structure interaction simulation is completed but there is a problem when I want to see the results.
In the Ansys How to video, the Structural solution is transferred to the Fluent result. But what I need now is to transfer the Fluent Solution to Structural. However, it seems that I am prohibited from doing so on MoExpress.
 So what should I do to see my fluid-structure interaction results, including mesh deformation, etc.
