Ansys Learning Forum Forums Discuss Simulation Fluids Cortex startup failure error issue: two-way fluid-structure coupling simulation Reply To: Cortex startup failure error issue: two-way fluid-structure coupling simulation
idenyu8701
No problem.
Thank you for your help. I have run the simulation again and it is now faster than 4 seconds.
The picture below shows the current running status.
