Ansys Learning Forum Forums Discuss Simulation Preprocessing Processing problems using the cyclic region function Reply To: Processing problems using the cyclic region function
dlooman
The difference between the stiffness matrix at different harmonic indices is the constraint equations created to enforce the harmonic index shape.  These constraint equations are created during solution.  A possible way to create a model for a harmonic index greater than 0 is to issue the command cycopt,hindex,N in a commands object.  Then the system matrices will be only for harmonic index N.
