Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with non-thermal equilibrium for porous medium › Reply To: Problem with non-thermal equilibrium for porous medium
chrivero
yeah i used superficial velocity but i also tried with physical only to check if the results were different. I use standard initialisation and then i patch the initial temperature of the porous solid
