Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem with non-thermal equilibrium for porous medium › Reply To: Problem with non-thermal equilibrium for porous medium
How does the mass flux balance look?  Turn off auto range on the contour plot, turn on filled and expand the scale (range) by a small amount at each end (so 0 to 5ms would be -0.01 to 5.01m/s).  The porous region won't slow/accelerate the flow (read the theory) but equally shouldn't stop it unless the flow can bypass the porous zone.
