Ansys Learning Forum › Forums › Discuss Simulation › Photonics › LN phase modulator charge file not working › Reply To: LN phase modulator charge file not working
Guilin Sun
In such case, you may need to rebuild the simulation file from scratch and see if it works, if you know all the parameters. Please also try other CHARGE files and see if you can open it.
It is very challenge for us to duplicate this issue and thus find a solution. I can download, open and run it without any issue, even with older version
 'unknown exception' is usually from your computer, such as C++ library. Please update your OS.
Now 2024R2 is released.
