Ian Pond
Hi All,
Replying in case others run into a similar issue. First off, Thermal Desktop is not compatible with AutoCAD 2025, so first be sure that you are on a version other than that. From there if you still receive the quick flash then close issue, please edit the following file, "C:\Program Files\ANSYS Inc\v242\CRTech\Thermal Desktop\TdDwgLauncher.exe.config" (where v242 is whatever version you are on) and uncomment the line with the path to AutoCAD, something like this . Save the file and try running again.
