Ansys Learning Forum Forums Discuss Simulation Fluids Segmentation Fault : udf for scalar Reply To: Segmentation Fault : udf for scalar
You shouldn't need UDMs, but double check those macros are available - you may need to tell Fluent to retain data as some of the gradients are not held in RAM by default. There's a TUI command in the manual regarding that.
