Ansys Learning Forum Forums Discuss Simulation Photonics No Filtering Effect of Travelling Wave Electrode with Sine Wave Reply To: No Filtering Effect of Travelling Wave Electrode with Sine Wave
kyle.johnson
I would recommend connecting an Electrical Network Analyzer with the "analysis type" property set to "impulse response" to the TWE element while changing the properties to see the effect on the element. This will give you the entire spectrum of the element's reponse instead of just the properties at one frequency, which is what you get with the sine wave source. This will give you a better understanding of what changing each of the properties does to the element's response.
As for the different number of samples, this is normal. The signals generated by each of the sources could go through different delays, so they may not have perfect overlap in time at each of the elements. This results in fewer data points recorded by the monitor.
