Ansys Learning Forum Forums Discuss Simulation Fluids Problem with non-thermal equilibrium for porous medium Reply To: Problem with non-thermal equilibrium for porous medium
What are you displaying the velocity contour(?) on? You're right in that a solid zone is created but flow is passing through the fluid zone so shouldn't be effected by the walls, it will see the porous media!Â
