Ansys Learning Forum Forums Discuss Simulation General Mechanical Mapping stress isnt congruent Reply To: Mapping stress isnt congruent
Erik Brendel
I want to try this instead of the inistate command, because  I need to solve a mechanical model twice where thermal loads are appllied. The special thing is that these 2 thermal loads need to be active at the same time, but this isnt possible in one model, because the one thermal load is an expansion through an chemical reaction which is modelled through temperature and the second temperature is just the normal temperature. So i want to solve the model with the stresses and strains through weight and chemical expansion of the first model, I want to export this deformed geometry to the second one and apply normal temperature on this. In this one I want to import the stresses and strain as this one video shows, that I watched:
&t=679s
